OK need a little insite here.
Took my 5600 up to the shop the other day do to a bad injector.
they replaced the #4 injector, adjusted the valves and also the injector pump timming. and replace the fuel line from the tank to the fuel filter. Got it back friday and it would start up and sound like a kitten purring, sounded great.
Well today I use it for the first time to bring up some dirt and after running it for about 30min it losses power to the point of full throttle is like a idle. and going up a small incline will kill it out.
Can restart it and it runs at full power for about 3-4 min then repeats everything.
any clues to what I should check before I take it back.
Heres some of the things I done before I took it the first time to the shop.
New full filter, new air filters, cleaned the tank ( it was dirty) cleaned the screen on the shut off val. checked the oil for water (none).
thanks for any help
clay
thanks for any help
clay
