power steering 641 update
dmbinva
Thanks for the pics ltradog , but I had the valves in correct. I pulled one steering cylinder loose from the front and I could push it closed and pull it open with hardly any effort. And could hear a gurgling in the cyl. I believe I have 2 bad Cylinders. I guess the PO used it quit a bit with no fluid in it and burned out the inner seals. I have a good pair that I will try ASAP
Thanks Boss
