I have the rocker cover off to see if I can determine why diesel fuel is leaking into the crankcase. My belief is that this is happening mostly when it is running, b/c I always shut off the fuel when I'm done using it, yet there's still fuel getting in. (Nonetheless, I have also replaced the cup seals on the pump.)
Question is, where does the return line typically leak? I'm not really in a position to start the engine at this point to observe, so where do I begin looking, or what seals should be replaced? The fuel tank is off, so I have good access.
Can the line be pressurized and tested somehow?
Thanks for any advice.
