Wow, thought I had my hydraulic problems licked on Saturday. I yanked the unloaded valve and cleaned and lubed it, checked for proper drag on the o-ring. Re-installed and all seemed well. Lift operated best yet and I happily mowed for about an hour. Feather light pinpoint control. Lift operated at lower rpms than before....I installed new wobble shaft seal, packed needle bearing, new pump gaskets, balls, and Springs. Sunday I go to mow and lift won't raise.
2500 psi pressure gauge should arrive this week. Gonna keep trying. Getting pretty good at yanking top cover. Will probably drain reservoir and clean the sump again. Anyone running an external filter?
