3 pt lift arms height
How low should the 3 pt lift arms on a 4 cyl Ford 2000 tractor go? The lowest mine will go(on the non-adjustable side) is 19 1/2 inches. This seems to be too high. If I am correct, and it should go lower, what are the possible causes?
Thanks,
Tex
The rockshaft arm should be horizontal when the hitch is fully lowered. The rest is determined by whether the tractor has the correct lift rod, leveling box, and/or draft links.
Are the drop arms the right way round? If you look at where the drop arms join the lower links you will find one side of the drop arm has a longer slot than the other. You need the long slot towards the tractor.
post a pic
do the arms drop when off, or in draft mode?
anything mechanically holding them up, as another poster mentioned?
