Ford 3000 Block
crosso
New User
Hi all, new to the forum and starting out with a problem ... hope to get some advice. I have Ford 3000 diesel and have done some damage,the number 3 piston has pushed through the block. The head was re built not long ago and am looking for advice or if anyone knows where I can find a block?
Where are you located? I have a block that is either a 3 or 4000. I also have a 3000 gas engine that is the same block as the diesel I believe.
Did the piston come completely thru the block or just damaged the cylinder?
If only cylinder damage you may be able to fix it with a repair sleeve.
