A bit of an odd duck
looks like the farmall shifter is still there.. but behind the seat??
hard to tell from the angle, and on a phone, what they have donw with the ford trans.
That is what grandpa would call chicken coop engineering. Take two machines a part and build something that doesn't look like either one.
The rear half is a Farmall F14.I like how they added a Farmall M seat in front of the gear shifter.
i emailed the guy for a pic showing the mating.
it's a ford 5spd. the 5 spd is bolted to an adapter plate with a spacer, with that spacer then bolted to the front of the f14? trans.
I guess if you used both trans you could get some pretty odd combinations, including reverse :) options.
