ford 2000 to 3000
The flywheel will swap so long as the donor and recipient have the same clutch configuration and fuel type. If the fuel type is different, the ring gear must be swapped to match the recipient's starter.
RickB is correct.
To elaborate a bit on what he said:
For all intents and purposes a 3 cylinder
2000 and a 3000 are identical machines.
However, Ford put about 4 different
transmissions in those tractors and they all
use a different clutch and flywheel.
So it is important to get the right one.
What is wrong with the one you have now?
