6 volt generator
(quoted from post at 15:55:10 05/11/16) how does one determine weather a generator is an A circuit or B circuit unit?
ook here (remove the *):
http://www.nt*ractorc*lub.com/forums/nboard/messages/232476.html
Check how the field is wired. If its wired to arm and barrel stud it is a
If it is wired to ground and bbl stud it is b
You can motor test it and see what field does grounding it like a. If that works, you can guess a, if not hookup as b and apply power, if that works, guess b. :)
