It's 32 1/2" inside to inside.(quoted from post at 12:05:12 05/13/16) Can you post the distance between center of posts?
I am looking to make one for my Farmall H, but would not need to make whole thing if it fit.
Thank you for the info. The tractor must have been in a accident and sheet metal replaced. On close inspection it has been repainted, but not recently. The hour meter shows 4400, which doesn't really match the condition of the paint. I'm crossing my fingers that with good maintenance and the sort of use I will give it (hay work, light loader work) it will work without major issues for some years to come. I do feel that I got a good deal on it for $5500.(quoted from post at 07:52:43 05/15/16) Model CA313C:
CA3 is a 3610, not a 3910
1 is a diesel engine
second 3 is a live PTO
C at the end is an 8 speed transmission.
Unit 2J28E:
September 28, 1982, but the last letter should be an "A", "B", or "C", so it is most likely a B, not an E, which would be the day shift.
