6610 II Loader CCLS return line
David G
I am currently returning the oil from the loader via a 5/8 return line into the tube on the side of the filler.
I would like to upsize this to 1", where can I tap this in?
5/8 is plenty big for 17 GPM return. I'd maybe consider 3/4, but nothing larger. You really don't have much to gain by going bigger.
Another thing to think about: That 17 GPM is not constant, since you're not using an open-center valve. If it were open center, you might have a reason to be slightly more concerned about back pressure.
