CHECK VALVE/BACK PRESSURE VALVE PARTS.
ZANE
I'm trying to get the lift going on a 601 tractor that someone has just thrown together and lots of the parts are missing or rusted beyond repair.
Right now I have got to find the parts that go into the front of the lift cover. The O ring and spring retainer/ the spring and ball. I do have the plug.
A good usable used one will be fine. Any help in locating these parts appreciated.
Thanks, Zane
I can't send pictures because the parts are missing.
It is the back pressure/check valve that sits horizontally under a plug at the front right corner of the lift housing on a 601
The spring guide/retainer that carries the O ring. The spring that goes behind that and the steel ball.
Thanks, Zane
Can you text me at 256 493 0450?
Or I can text you from parts book if I had your smart phone number.
My email is [email protected]
Zane
(quoted from post at 18:57:36 05/01/16) I can't send pictures because the parts are missing.
Thanks, Zane
Zane
f you need picture of those parts, just ask.
Here's a picture of the parts Zane is looking for.
