showcrop
I posted a few days ago about needing to secure the PTO handle/shaft onto the cable end. Well I figured it out and got it attached but it remained to be seen if I got the length to within the required range. I had turned it about three turns out of the trans cover, but needed to work with it to really be sure that I had it right. Well yesterday I was spreading fertilizer, so I turned it on and off a number of times. Each time it started up and then shut off just as you would want. The spreader of course isn't much load, but it was enough to stop it from turning.
