showcrop
I think that I got it fixed this evening. I will have to hook up an implement in order to know for sure. It was the rod or shaft that the T handle attaches to that had threaded off the cable. I had to thread a little out of the tranny housing in order to have a half inch for the handle shaft to thread onto. For awhile after I repaired the inside linkage and the handle wasn't tight I had turned it CW a turn a couple of times and that had threaded it part way off, then finally it came out. I cleaned up both the cable end and the inside of the shaft, and put blue Loctite on it to make it stay.
