Brian J in MN
When shifting from 4th to 5th and from 5th to 4th even using the inching pedal, there is a noticeable jerk(like a slight lockup on tranny). Can this be caused by the spring loaded check balls in the servo interlock being weak or bad seating area for check balls?
This tractor has always done this. My dad purchased it used back in '61. It's a 1960 and it had a lot of tranny problems(previous owner abused it and was NOT clean with tranny oil) filter was not put in until after my dad purchased it.
