881 172D engine questions
I overhauled this engine around 1978 and when I assembled it, the only type of rubber seals for the injectors that fit in the head were not the kind I needed(need the style that has a wider portion in the middle of the "U" not the narrower type).
Can you get either type now? If not I am open to ideas on how to keep them from leaking oil.
Brian
Ordered seals from ford, hopefully they will be correct. Stumbled onto something I forgot about(just remembered my dad mentioning it). Around 1974, head gasket went out on tractor and dealer at that time switched the head out to a later type(probably a 4000 4 cylinder).
