SOS PTO Handle
showcrop
Ever since I repaired my interior PTO linkage the handle has not been tight on the cable. If I turn it on too far it will thread too much out of the interior fitting. Last time I went to use it the handle pulled out. There is no set screw on the handle as you would expect. What is supposed to keep it on the cable end? I suppose that blue Loctite would work.
(quoted from post at 07:35:43 04/22/16) Ever since I repaired my interior PTO linkage the handle has not been tight on the cable. If I turn it on too far it will thread too much out of the interior fitting. Last time I went to use it the handle pulled out. There is no set screw on the handle as you would expect. What is supposed to keep it on the cable end? I suppose that blue Loctite would work.
I'm having trouble deciphering your meaning. Are you saying the shaft that the T handle attaches to is coming off the cable?
