Old 4000 left brake cross shaft
makoman
Installing new brakes. With brake shoes off, left brake pedal shaft under tractor not spinning easy, needs grease. Loosened nut on brake arm but cant slide arm off shaft. Its a little loose but not coming off. Any tricks? That shaft should push through to other side correct? Was hoping to clean grease reinstall.
I just had the same problem, I removed the right side and left side rods and had to drive
the cross shaft out with a brass drift and a BFH . BE SURE the cross shaft is NOT mushroomed
on the end your driving on. If it is rotate it and grind off the mushroomed end. It worked
for me !! 505-620-3040 Jim in N.M.
