3600 3 pt trouble
Erik OK
I recently got a 3600 that had been sitting in a barn for about 10 years, when I got it started the 3pt arms raised all the way up and it sounds like the hydraulics are under load. I got a service manual and everything in the troubleshooting talks about if the lift won't raise but there isn't anything about if it won't lower. I'm assuming I will have to pull the top cover but what should I start looking at once I get it off? The unloading valve, control valve?
if itges up and sound slike it is under load, then the system is in lift mode and not unloading.
unloader would be my first thought.
