Replaced diesel fuel return line with weed eater fuel hose?.
jwjsr
I trashed the original return line that goes from the Cav pump to the first injector and replaced it with the transparent weed eater fuel hose I had quick acces to, Anyone see a potential problem with this?
It should be fine, I have seen that
stuff burn as others said on weedwackers
and it just chars the same, might not be
as durable to impact and abrasion tho. I
would order proper stuff next time you
get parts but wouldn't be afraid in the
time being
(quoted from post at 15:51:03 04/13/16)
If it's not rated for diesel fuel, the diesel fuel itself will eat it up sooner or lTER!
I put some clear tygon on the diesel return lines on my Kubota 2 years ago, no problems so far.
About 15 years ago the return line on my JD 4430 started leaking.
Deere wanted over $100 for a new line. I made my own with yellow
Tygon fuel tubing. It is still working today.
Tygon is fuel line, just a different type. It is intended for fuel oil, lubricating oil and such so not as issue
