5200 instrument cluster hookup?
paul
I got a 5200 and I believe I hooked the various wires up wrong, wondering if there is a good diagram anywhere? My pictures I took obviously
weren't as good as I thought......
Paul
I'd be interested in this too. I hooked up my 3400 and the temp was pegged at startup so I reversed the wires and now I've got no electrical readings. Manual doesn't specify which side gets which wire, just to make note as you disassemble. When you've got a disassembled basket case that gets difficult.
Thanks! Will check that out when it warms up in the mext few days.
I suspect my generator needs service as well, but no point when one has the wiring wrong......
Got a new battery in it a couple days ago, so one issue off the list so far. Pulling the negative when not in use.
Paul
