My 3400 Ford leaks power steering fluid out of the top of the steering column. I have replaced the seal down by the steering box several times. I have also installed a speedi sleeve to cover up the grooves in the shaft. Whenever I have removed the seal to replace it, it looks perfect. After studying the hydraulic diagram it appears that this seal only should seal very low pressure, it is connected to the fluid reservoir. My fluid reservoir seems to have pressure in it when the tractor is running. My question is should the fluid reservoir be vented? I looked up the specs on the seal and it is a low pressure, approximately 10 PSI seal. I only seem to get the leak when I run the tractor down the road and turn the engine at high RPM.
Any ideas? I hate to keep changing the seal and have it leak again.
