2600 and 340 hydraulic top swap?
GreenAcre
Thinking I'll keep the 340. 2600 has a factory one way valve in place of the blocking plate. They physically interchange, but can I swap them and put the valve on the 340 and the 340 top plate on the 2600 without issue? Thanks, Matt.
When I put on my Woods backhoe I removed the top plate and put on a porting block to run the backhoe. 2600 has good flow and runs the backhoe at a good speed. The pump assembly on the backhoe attachment was extra money.In my opinion the porting block is better than a PTO drive to a pump on the backhoe. You can use the porting block for other uses as well.
Parts site shows the same part numbers for the main top cover parts between the 2600 and 340, as well as the blocking plate, so they should swap fine.
