Wheel weights
While restoring my 1963 2000 Industrial, I'm removing the rear wheels and weights. The weights are 8" wide,2 in.thick, and 21 in.Diameter. The only numbers cast into the weights are, "ball" and "8 LX" Can any of you help with any information on these, like how much they weigh? Oh yes, they fit on the inside of the wheel and are held by 3 bolts to the cast iron center disc. The other 3 holes hold the rim onto the cast iron disc. Any help will be appreciated....Jim in N.M.
Stackable plate weights are a little over a hundred lbs a piece. The center disc is about 125 lbs.
Here is a photo of the stackable Ind weights.
Kirk
