601 rpm gage
tp
My 601 rpm meter needle started swinging back and forth across the better half of the gage continuously. I unhooked the cable ends and both ends appear to have good flats and fits so assume no slippage or binding of cable. Is there a gear in the meter itself that might be causing this or something else? Any ideas short of replacing the gage.....as this will not happen....would be appreciated.
Thanks, TP
Yup, the tach section is having issues.
Some of us pry the bezel up, clean n lube and re crimp.. But its an un-fun task. I mostly run by ear now anyways..
