Sorry for the repost, I accidently posted in the fordson forum. I have a 1966 Ford 4000 that has a 192 gas in that I'm overhauling because of blowby. #3 piston has two rings broke and top one partially missing. At what point is it still permissible to use std pistons. The bores aren't torn up too bad that honing may clean up the cylinder. If I have to have it bored, is there any cylinder issues that typically result afterward? I'm just worried about the life of the block being bored. Is cracking or porous holes leading into the cylinder prevalent to these engines? I haven't measured the bore yet to see what size it is. What are the specs for bore size and recommendations to install oversized pistons. Most engines I work with you can hone about .008 over before boring. Any help or recommendations would be appreciated. I don't want to do this job twice. Thanks in advance.
