I am looking at overhauling the steering on
my 3000 diesel. It has powersteering and i
believe it to be a 68 year model.
First question i have is the radius arm
supposed to have movement laterally front to
rear? Mine has this movement and wondering
if it should and if not should just the
radius arm cap be replaced or the cap and
the arm?
Second question is the ram cylinders, what
is the benefits between the 1/2 and 5/8 ram
cylinders? I am leaning towards the 5/8 as
based off the description it comes with the
male threaded balljoint end where the 1/2
ram does not. Be more cost effective.
Third question is on the steering hoses,
mine are short ones that loop around to the
hardline connection below the ram cylinder.
Can you still get theses or will i have to
go with the replacement and get rid of the
hardline?
Fourth question, sometimes i get a watery
black fluid that comes out from under the
steering wheel collar. Is this just water
getting in and washing grease away? I dont
want to fix hydraulic steering leaks if the
gearbos has one as well that doesnt leak all
the time.
I might have more questions latter but this
is what i am thinking of right now.
the arm?
hardline?
the time.
