HD Industrial Spindle Bearing Question
I am replacing King Pins and bushings on a Ford 1801 H.D Industrial. Does anyone have a good bearing number for the lower bearing that is on the spindle, the only number on the bearing that is visible is H-26, the New Holland part # is C7NN3123A. I just wanted to grab two from NAPA and not have to spend double the $ at New Holland. Thanks for the help.
NH's not too bad, Messicks shows them for-
C7NN3123A $20.14 BEARING ASSY,28.74mm ID x 55.82mm OD x 15.88mm W., Spindle Pin, Years: 01-JAN-58-31-DEC-62
