860 release carrier needed
Well, I split the 860 (1955) I picked up that had a "bad" clutch. P.O. had "adjusted" it, then it ran for a few, and quit. Well, his adjustment led to the clutch fingers being worn through, the release carrier somehow sitting behind the forks, and the carrier is worn through on one side in the area that the bearing sits. So, I'm trying to find one part# NDA-7571-C. Any help would be most appreciated. Or if anyone knows of any tractor junkyard near Berkeley Springs, WV/Hagerstown, MD, that would be awesome!
Thanks!
That part number you listed is not showing up in the parts drawing. Is that just the number cast or stamped on the part? If so, it's probably not the actual part number. Look at the parts drawing here to find the correct part number:
[u:ed91b92618]Ford 860 double clutch assembly parts diagram[/u:ed91b92618]
There are a couple of salvage yards in Pennsylvania not too far from Hagerstown, MD. Both Long Lane Tractors in Elizabethtown and Wengers of Myerstown are just on the far side of Harrisburg from you.
Here it is at Wenger:
http://www.external_link/parts/Farm-Tractor-Parts/Ford/Series/900/CLUTCH/Sub-Component/RELEASE-BEARING-HUB/01-7571C_NDA.htm
I've found the new holland site diagrams incomplete more than once.
Trying this again, not seeing my first reply, so sorry if this doubles it-
The diagram doesn't show the carrier. Wengers does list the part, but is out of stock. I tried linking in my previous post, that didn't exactly work, lol.
Yes, that is the number cast-exactly NDA-7571-C.
Ok, it's on there, as a clutch hub-looks to be made of "Unobtanium", as the superseded part number (86531345) comes up with no hits....
partspring.com has 32 of them in stock as well, at $166.00 a piece.
Feel lucky that you have the earlier one. That hub is listed twice on the parts listing, once with the part number you posted for tractors before serial number 14257, and again for tractors with serial numbers above 14256. The part number for the later one is 86539876, and partpsring.com has 8 of them in stock, but they are a whopping $452.00 a piece.
(quoted from post at 14:31:10 02/09/16) partspring.com has 32 of them in stock as well, at $166.00 a piece.
Wow!! Another $50, and it's what I paid for the whole tractor, and it has new tires on the rear....
I saw parts spring come up-have you, or anyone used them?
And thanks to all for the replies!!
Yes, I've bought a few things from partspring. No problems with any transactions so far. They are a New Holland parts dealer, so if you order something with a New Holland part number you will get a New Holland part at New Holland prices.
There are a couple of New Holland dealers not too far away from you, Winchester Equipment Co. in Winchester, VA and Antietam Tractor Equipment in Hagerstown, MD.
(quoted from post at 07:04:11 02/10/16) Yes, I've bought a few things from partspring. No problems with any transactions so far. They are a New Holland parts dealer, so if you order something with a New Holland part number you will get a New Holland part at New Holland prices.
Cool. Thanks again.
