Dapollack36
So I took my 555 out today, pushed the brakes to release the parking brakes and it felt like something popped and now no brakes and the peddle goes to the floor. Any help would be appreciated
(quoted from post at 03:06:36 02/08/16) I know you said you checked the linkage.... but I think you should check it again. If it was just one brake affected then I'd say it was probably an internal problem even though that is odd. Given that you say BOTH are affected... that to me would be almost unheard of. I'm just wondering if one of the mounting points for a linkage fulcrum has come loose or something. That might allow you to see some movement in the linkage but not apply any real braking force. But if you are truly seeing a full steady range of movement on the brake actuator rods at the axle housing on BOTH side.... then I pity you. As Bern said, those axles are a pain in the arse to remove, heavy, etc. It's not a bad job on a tractor but on those hoes... it really sucks.
I think Rick is the one to give you a tutorial on that subject...
Rod
