counterclockwise
I'm working on a 9xx series 172 cu. in. diesel and have a couple questions. It needs a balancer assembly and crankshaft. It has the "service balancer" that attaches to the center main bearing cap. Will the gears from the factory installed balancer install into the service balancer? Next questions are about the crank. Are the new aftermarket cranks good to use in the diesel applications, or should I look for a good used crank? My Ford service manual says not to turn the diesel cranks and I'm sure there is a slim chance of finding a used crank that is still standard and good to use. Or can the diesel crank in fact be turned?
Any good sources for these parts? Thanks
