Can't find parts( HELP)
Well here goes, I'm restoring a 1963 Ford 2000 Industrial. Called the FNH dealer looking for the rubber dust cups for the drag link to the front spindle arm. And the power steering piston front and back from the radius rod to the drag link. They are not all alike! There are a total of six(6) FNH says "Not available" So I'm asking any of you good guys out there if you might know where I might find some? Have any of you run into this problem? My email is open if you want to email me a phone # and a good time to call I'll be happy to call you!! Thanks in advance. Jim in N.M.
I got all my steering cups and felt seals from my local New Holland dealer, and that was just last winter. I was working on a 64 4000 industrial with the heavy front axle and power steering. Sometimes when you look at the parts catalog it will say not available, but when you bring the part info up, it will give you a superseded part number with a replacement that is still available.
This site has many of the parts also.
(quoted from post at 18:58:03 02/05/16) My email is open if you want to email me a phone # and a good time to call I'll be happy to call you!! Thanks in advance. Jim in N.M.
Not that I have any answers for you, but I also don't see any open email for you! None here in modern view. None in classic view either.
Google is your friend. I looked up the original part number for the first one you mention at the front of the ti rod, and the original part number was C0NN3A301A, and then I Googled that part number and he first hit back from Google was the link below that sells a generic one for $3.00 apiece and it lists all of the different brands and models that it's supposed to fit, and it claims to fit the Ford Industrial 2030 and 2130, which were th official model numbers the 1961-62 and 1963-64 2000 industrial model, respectively. Well, this site apparently won't let me post the link because they are a competitor, so take the line below and remove the blank spaces and paste it into yourbrowser's address bar:
http://www.tractor parts asap.com/Tie-Rod-Boot-Case-IH-International-Ford-p/151981.htm
Unfortunately the second one you mention, at the front end of the cylinder is just listed on the parts diagram as "PL" for "Procure Locally" and doesn't list any other information, so for that one I would take the end off of the cylinder and take it to NAPA or some place like that to see if they might be able to match one up for you.
The last one you mention, at the rear of the cylinder does list a part number, 59T3332, but the only things I'm finding on that one are used ones at salvage yards, so I would take that end off and take it to NAPA as well. Heck, no need to take the ends off, just take the whole cylinder.
As for Mark-Ia's response about them being available here on Yesterday's Tractors, the only one that I can find is the one for the rear end of the tie rod itself, which is the only one that you didn't ask about, but I don't think that's the correct one for your tractor anyway, as it lists a ton of model numbers that it's supposed to fit, but the Ford part numbers referenced don't match up with the parts site. In fact, the parts site says that one for the rear end of the tie rod is actually the same part number as the one for the front of the tie rod, so it should be the one that I posted the link for above.
I Found an odd bit of information. One of the Google hits on that last part number, 59T3332, is a GM parts lookup PDF file that lists that part number as a tie rod end dust cover for a 1973-1977 Ford P350 truck, which was a Ford step van. Unfortunately everything else I can find on that part number says that it's obsolete and no longer available. But I did find this link, which claims that there are 5 of them available at two different obsolete parts dealers:
[u:19bc280beb]http://www.rearcounter.com/59T3332-parts303919.html[/u:19bc280beb]
