I was pushing snow the other day and noticed a pretty steady oil leak after about 20 minutes of operation. There was a very slow stream of oil running down the lower front cover of the bell housing just behind the oil pan. This is a Hundred series tractor so it doesn't have the structural oil pan.
There is no oil leaking from the clutch chamber, and although the cotter-key is missing from the weep hole, the hole is clear.
Is this likely to be something OTHER than an oil pan gasket in need of replacement?
Brian
Brian
