tiresharkdbb
New User
Want to say thanks to everyone for all the information on this forum. I had several fuel leaks, and by reading the threads here i was able to find out what i needed to do to repair them.
Decided to do the 'drill out and repair' method, that is talked about often, and that Texas did a tutorial on (in the thread i linked below). Spent an hour or so taking the body panel off, and finally got the tank off... much to my delight, someone had already performed this repair at some point in the past. So all i have to do is replace the seals and put it back together. Couple of questions:
1. Are neoprene orings ok to use between the valve/tank and for the oring inside the valve? Does it matter if i use a flat washer or an oring between the tank/valve?
2. There is another fuel shutoff just above the sediment bowl that was leaking... i was thinking that i would do what Greg1959 did in this post, where he replaced all of that with brake line and a ball valve.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=551799
So to do this, do i just get a few feet of 1/4" brake line from autozone or something, and then just bend it a little with my hands? Anything special i should ask for, or will they know what i need if i just tell them i need some steel brake line? (never bought any before).
Thanks for any advice!
