Aussie Ken
Was at a farm today in Australia working on a tractor, when I saw a Ford 3000 later series with the flat grille --it had been parked several years ago when the owner was bush hogging the side of the road and the roads guys had put a steel post in the grass and he did not see it - the post struck the side of the injection pump and broke a plug off of the plate on the side -he said he drove it home and the tractor started to miss and he parked it where it sits now - and bought a neighbour's larger tractor-a 1040 JD -I did not take any pictures -should have - the tractor is not seized -manual steering, two stage clutch -sank down in the dirt its been sitting there so long - he would sell it - not sure what model injection pump it is -looks like a CAV -identical to the one in the YT picture- possibly there is nothing wrong with the pump??? and it started to take on air through the broken plug ???? What does that stem and plug do that are mounted to the plate?
Thanks in advance
Thanks in advance
