Dopp Creek
I have a 1967 3 cyl 4000 SOS that is leaking at the PTO shaft. Looking through the online parts catalog I saw there are different seals depending on whether you have single speed or two speed PTO. My operators manual has an illustration of a small lever under the SOS filter that changes speeds (540/1000) and a second lever behind your left heel for Ground drive PTO described as "Deluxe PTO". My tractor has the small lever but not the one for ground drive. Does a "Deluxe" PTO have both two speed AND ground drive features? What is the small lever for in the absence of ground drive? I just split it to change a hydraulic pump seal and it's not running yet(waiting for parts) or else I'd just go try it.
Thanks for your help. Tim
