64frd4000ind
Well after a busy spring, summer and fall I'm back to work on my baby.
1964 Ford 4000 Ind. SOS.
3pt lift arms will not pick up.
Hyd Pump will not self prime, and when I apply 5lbs of air to dipstick I get flow, but no pressure.
Proofmeter works fine, so I know the gear is spinning.
System worked well before the rebuild, but I would have to purge air from the pump from time to time.
Question is, has my pump finally gave out/stuck? What else to check before I take it off and see about having it rebuilt?
