NAA and hundred serious hydraulic valves interchangeable?
markct
I have a hydraulic auxiliary valve (on the
top cover under the seat) on a Ford 600
here and am wondering if anyone knows if it
will bolt up to the NAA, just figured I
would ask before I go unbolting them.
Thanks Kirk, was looking at a snowplow that came with the valve and wondering, I will email you tho when I get a minute would be interested in it for sure if price is reasonable
if yuo just need SA hyds and no 3pt, you can chain the 3pt down and run a line from the naa blank cover plug to your cyl.
if you need DA hyds but no 3pt, then run from that plug to a genericOC spool valve that will run your DA functions, then return it to the tank via a fitting tapped into the fill cap or at the dipstick plate using a bulkhead fitting or similar.
Thanks soundguy, I knew that but forgot all about it! And yes I only need single acting for snowplow.
