2000 1975 loss of fluid
makoman
Hydraulic line pushed out of pump under load, replaced nut and bushing so all good, not leaking. Filled fluid back up (lost about 3 gallons). Now 3 point jittery going up. 45 degrees outside, did not really let it worm up. Air in line? 3 point was strong before this.
You probably have air in the suction line/pump.
If you are getting some lift go drive the
tractor around for half an hour.
That will likely get any air out and it will
work normally again.
