Changing pedestal oil in Ford 961
jenniejester
New User
This message is a reply to an archived post by awhtx on May 09, 2009 at 14:38:58.
The original subject was "Re: Ford 800 and 900 series fluid changes types?".
Can you tell me how to change the pedestal oil? I can't figure out where the drain plug is. The place where I think the drain plug should be has a square hole. Is that the drain plug?
On my TO35 I do not think there is a drain on the steering gearbox,
I think you would have to use a pump an suck the oil out of the gearbox.
The 961 is a row crop model, completely different from your T035.
There is indeed a pedestal drain. It may be hidden if you have a loader (or loader bracket) installed.
Opening the drain will likely drain a quart or two of water before the oil drains.
Dean
Thanks, I figured out the square hole is the drain plug. Now to get it to budge! So far my 1/4 inch drive is just slipping off. Can't find my cheater.
The problem I am experiencing is that when it's really cold out, it takes about 20 minutes until I have any steering. The oil in the pedestal looks like sludge, so I am hoping that getting the water out of there will fix this steering issues. Is this probably what the problem is?
(quoted from post at 04:19:38 11/29/15) Thanks, I figured out the square hole is the drain plug. Now to get it to budge! So far my 1/4 inch drive is just slipping off. Can't find my cheater.
Does it have power steering? It was standard on 961s.
(quoted from post at 06:04:13 11/29/15)
Unfortunately, it does not have power steering.
