1970 2000 ford
5000-nut
Gasser runs but not above 1200 rpm did all basic in ford Oem Manuel worked carb by hand and can go higher but gorvenor pulls it back..
Missing something small need some help input please thanks Steve
Did you set up the governor linkage to the correct lengths? Could be high idle stop screw or just the friction disk at the bottom of the throttle lever shaft.
