Has anyone removed, replaced or repaired the hydraulic oil pressure tube that runs through the length of the transmission? I'm working with one that the tube has rusted through and is leaking oil inside the flywheel housing. I've removed the trans and attempted driving the tube out from the rear(even have the original Ford/Nuday special tool NCA945A) but it's not moving at all, and seems to be compressing the end I'm driving on. Thought I'd better stop before doing unrepairable damage and research this a bit. Any thoughts on cutting out and splicing in the section of tubing through the flywheel housing area...maybe using a hydraulic compression fitting (union)?? I'm open to, and grateful for, any ideas.
