Ford 3400 Oil water issues
DustanD
New User
Ok the subject is a Ford 3400 3 cyl diesel 175
Replaced head gasket and could see where coolant was working its way to the oil return port even though the gasket looked in good shape.
Anyway now I still have a leak from the coolant to oil and its a quite large one. It takes about 60 seconds from pouring water into rad for it to steadily stream out of the oil drain plug. Heres the tricky part sometimes it doesn't sometimes I can fill the rad up and no leak. Engine runs great when filled with oil and coolant but every time coolant flows right into oil and sometimes takes a few minutes before it does.
So my big confusion here is how there could be such a large leak and then just no leak even with rad filled to the top. I could see maybe some gunk clogging it but seems it would be a large gash somewhere to flow out as good as it does.
Any ideas and experience appreciated.
Thanks,
Dustan
I'm afraid you probably have a cavitation hole in a cylinder. The times the coolant doesn't flow into the oil pan, the hole is likely being covered by a piston.
The cure is a rebuild, with the cylinders being bored out and skeeved back to standard.
Remove radiator oil pan plug water pump hose remove thermostat fill with water roll over motor to locate leak. If not found refit thermostat housing and pressurize 10 to 15 psi always locate leak before tear down as cavitation can also occur above the camshaft into the water jacket. good luck max
I had that problem. My brother investigated it and he says there was a leak in the intake manifold gasket. Without seeing it, I'm not sure what he meant.
