Loader operating with the original pump side of the engine.
When I want to raise the loader by pulling the spool valve handle no action.
If I operate the bucket cylinder for 2-3 seconds while holding the spool valve the loader will raise.
When the loader is raised at any position it will operate normally.
If I get the loader down I have to operate the bucket cylinder again 2-3 seconds to raise the loader.
As long the loader puts a down pressure on cylinders it operates OK
But bucket on the ground (no down pressure) I must operate bucket cylinder to raise.
When operating rising speed is normal and pressure is @ 2100 PSI
Any ideas ???
Thanks in advance
Bart
Any ideas ???
Thanks in advance
Bart
