flyntl39
New User
Now working on my first Jubilee. Looking from the back of the tractor to the front, there is two plugs of about 7/8" size on the right side of the transmission. I assume these are plugs designed to leak indicating when the transmission is full. One is higher than the other from the bottom of the transmission. Which is to be used, the bottom or the top?? Thanks
Maybe this will help if not send me an e-mail and I'll send this to you and then you can print it out
plug around your right heel, ont he trans casting, just above the running board is the fill to check plug.
don't be taking any bolts out.. or you will be emailing back in asking about an idler gear.. :)
