4500 outrigger pins and bushings
I had the same issue with mine. I just built up weld on the worn areas and went from there. The problem is that there isn't
much load bearing area on top of not being greaseable. They also spend a lot of time in the dirt and mud. I am not even sure
they are replaceable and may be welded in place.
