markgmurray
Hello, I have a 1965 Ford 4400 Gas 3cyl with loader, three point and pto.
From what i can see the model / year.
5M15C ( 1965, December, 15th, Afternoon shift)
44022C ( 4000 series, Utility, Gas, Pto Trans 540 and 8 Speed)
C128506 (serial number, also 6B22 after that?)
What I'm trying to figure out is I don't believe it is an 8 speed and the PTO has a separate control on the left side that I can raise/lower to engage the PTO. Is it common to change the PTO from trans 540 to Independent? Im assuming someone has in the past, not sure?
I have HI / LOW range shifter and the transmission shifter. It seems like when pulling the transmission shifter back towards me I can only get reverse and no forward gears. Is it possible its a four speed (2 low / 2 High) ? I can't seem to find a shift pattern.
Any advice is appreciated, thank you.[/img]
