Ford golden jubilee hydraulic pump
d.borcher
Just acquired a golden jubilee this is my first venture into Ford tractors but the hydraulic pump needs to be rebuilt but its a axial piston type pump not a vane pump like the book says what's the story behind this? Was there an update? The piston doesn't seem hard to rebuild if I get a hold of a kit and clean it up and check it out.
Did you check the output pressure? How do you know it needs a rebuild. Piston pumps are the upgrade, they can be rebuilt, the vane pumps were good but almost impossible to get parts.
