881 Rim Bolts
Lynn Patrick
Does anyone know a source for rim bolts for an 881, part #354571-S, fine thread 5/8"x1.75"? I can find the longer 2.82" x 5/8" for loop & hat rims all over, but none this length!
Thanks for the help!
Power Adjust rims????? Think you got the part # wrong. Messicks lists it as 35457158 and available. Hang on to your hat, however!!! They only want $48.64 for that danged little bolt!
Thanks for the response. Yes, PA rims. I got that # from my parts catalogue. Looking again I see it listed actually as #354571-S8. I checked Fastenal & they could not even order them!
Still think that number is incorrect for a couple reasons:
1. Messick's part number is 35457148
2. Your part number is not in New Holland (what Ford is now) format.
3. Messick's part number is in New Holland (what Ford is now) format.
4. New Holland (what Ford is now) typically uses a six or eight digit part number. They do not typically use dashes and letters.
Oops! I'm incorrect. It is354571S8. I see it listed several places, including eBay. All in the upper $40s range. Google it without the dash.
Try Ziegler Bolt and Part company. Might not be a perfect match, but the description I saw looked right. Grade 5. Not sure of what originals were.
Available from CNH but expensive.
Any GOOD fastener specialty supplier should be able to supply but might be a minimum order.
Dean
