ford 4600 throttle assembly
ben_fishn
New User
replaced my fuel tank. after having to wait a week for the right tank (sent me the wrong one), i forgot how to hook the throttle back up where the spring is on the lower part of the handle. could someone post a pic or diagram if they have one? thanks!
thanks sean! mine is diesel. the diesel link pic is not working for me bit the gas link looks like it may be the same.
question for you...how can i tell if its 4600 or 4600su? nothing on the tractor says su but i had to replace the fuel tank and ordered a tank for 4600 and it wouldn't fit. is there something in serial or model number that dignifies that is su?
4600SU has the radius rod front axle with two steering arms and pitman rods, one on each side of the tractor like a 2600 or 3600 or the earlier 2000 or 3000. The 4600 has a heavier duty front axle without the radius rods and a single steering arm and pitman rod on only the left side of the tractor.
The model number on a 4600 would start with DA1 or DA2, and on a 4600SU it would start with DS1 or DS2.
The parts site does show two different part numbers for a 4600 fuel tank depending on whether it had a cab from the factory or not, and the 4600SU shares the tank part number with the 2600 and 3600, which would make sense since the steering column mounts to the fuel tank and the SU has the same steering column as the 2600 & 3600.
